Old Jun 26, 2009 | 02:48 PM
ppro's Avatar
ppro
Default Re: Windshield washer fluid tank
From the Factory Service Manual verbatim
Removal
1. Disconnect the negative battery cable.
2. Remove the rear half of the right front inner fender liner.
3. Remove the washer fluid filler tube (1) from the washer reservoir.
4. Remove the washer reservoir attachment bolt.
5. Gently pull the washer reservoir (5) forward to release the
rubber mounting grommets.
6. Disconnect the washer pump motor harness connector and
remove the washer pump motor supply hose from the
washer pump motor (3).
7. Disconnect the washer fluid level switch (4) harness connector.
8. Remove the washer reservoir from behind the right front
wheel.
INSTALLATION
1. Connect the washer fluid level switch harness connector.
2. Connect the washer pump motor harness connector and
install the washer pump motor supply hose.
3. Insert the washer reservoir behind the right front wheel and
align the rubber mounting grommets.
4. Install the washer reservoir attachment bolt (2).
5. Install the washer fluid filler tube (1) to the washer reservoir.
6. Install the right front inner fender liner.
7. Connect the negative battery cable.
