Windshield washer fluid tank
Old Jun 25, 2009 | 08:50 PM
Goldwing's Avatar
Default Re: Windshield washer fluid tank
The pump will happily **** water or windshield fluid. FIrst thought is check the fuse.
Old Jun 25, 2009 | 08:52 PM
chris070's Avatar
Can you give me an idea of where the pump is located or what it looks like?
Old Jun 25, 2009 | 08:54 PM
chris070's Avatar
Yeah I understand it overflows after a gallon, my problem is nothing comes out. But yeah I already checked the fuse its fine. Im pretty sure the pumps bad but Im not real sure where it is.
Old Jun 25, 2009 | 09:57 PM
Cadetgray's Avatar
My washer warning light went on yesterday for the first time since I have owned the car. I picked up a gallon of washer fluid to refill it. I was amazed as I kept pouring and pouring. I kept looking on the ground but nothing was leaking out. I even looked again at the cap logo to confirm that I was pouring it in the right place. I've never had a car with such a large reservoir. I was a humorous moment though...LOL
Old Jun 25, 2009 | 10:34 PM
Display_Name's Avatar
Old Jun 25, 2009 | 10:40 PM
magneticred's Avatar
The pump is located with the reservoir.
Down load the service manual : http://www.majormotorshotrods.com/_d...ice_Manual.pdf (this and other neat stuff is in the SRT sticky section).
Go to 8R-32 in the service manual.
Old Jun 26, 2009 | 12:30 AM
Squirrel Crusher's Avatar
I just removed my washer tank. Lined the fender and fender well area with a plastic bag misted with water to activate 3 cans of spray foam. I now have a mold I can take around to the salvage yards,searching for a smaller tank. Has anyone fitted a smaller,shorter tank in this area to save me from salvage yard searching? This tank is holding up my mods. Will be piping true aluminum ducts from the engine compartment,hidden under fiberglass covers simuliar to the new Corvette's side vent. The cover will be open front and back to remove engine heat. There's nothing in the drivers fender. I'm just not a fan of our fake strakes. There's actually rust forming behind them. The strakes are taped down on the back,but the front has three small raised U shaped areas that are wearing thru your paint from road viberations. Squirrel Crusher
Old Jun 26, 2009 | 07:46 AM
chris070's Avatar
Thanks magneticred Ill give it a shot tonight.
Old Jun 26, 2009 | 02:48 PM
ppro's Avatar
From the Factory Service Manual verbatim
Removal
1. Disconnect the negative battery cable.
2. Remove the rear half of the right front inner fender liner.
3. Remove the washer fluid filler tube (1) from the washer reservoir.
4. Remove the washer reservoir attachment bolt.
5. Gently pull the washer reservoir (5) forward to release the
rubber mounting grommets.
6. Disconnect the washer pump motor harness connector and
remove the washer pump motor supply hose from the
washer pump motor (3).
7. Disconnect the washer fluid level switch (4) harness connector.
8. Remove the washer reservoir from behind the right front
wheel.
INSTALLATION
1. Connect the washer fluid level switch harness connector.
2. Connect the washer pump motor harness connector and
install the washer pump motor supply hose.
3. Insert the washer reservoir behind the right front wheel and
align the rubber mounting grommets.
4. Install the washer reservoir attachment bolt (2).
5. Install the washer fluid filler tube (1) to the washer reservoir.
6. Install the right front inner fender liner.
7. Connect the negative battery cable.
Old Jul 17, 2009 | 11:31 AM
ppro's Avatar
Old Jul 17, 2009 | 11:41 AM
chris070's Avatar
Thanks for the help guys I was actually able to just replace the pump myself which seemed to fix everything
syfi
Mar 28, 2026 04:14 PM
jimf
Oct 10, 2015 10:22 AM
paine2907
Oct 2, 2015 10:01 AM
Sep 26, 2015 10:21 PM
Jackobo
Sep 24, 2015 10:21 PM
