Old Jul 1, 2009 | 10:40 AM
tighed1's Avatar
tighed1
Default Re: Central locking & ESP
I don't think you are going to see voltage at fuse 13 until the pump circuit is on. If you jumper a hot wire to this side of fuse 13's connection your pump will be on as long as the key is in the ON/RUN position.
Kinda hard to tell when the pump is running. Gotta listen real hard.
