I'm running a GY Gatorback 8PK2910,, 4081145 on the Code 3.
SMPSHADY is right though. You out to be able to find some slack in a tensioner. How big is you back turn wrap pulley? Mine adds about an inch of travel to the belt's path.
roadster with a stick
its the oem timing idler pulley tighed1 used in his belt wrap. it added travel but then running under the factory pulley next to the s/c should add the same i thought. im going to recheck everything in the am and then fire the car up to see the belt travel
