Re: belt wrap question
The Belt Wrap setup I use, uses the stock belt. Understand that is while running the 181 crank pulley (takes up some belt slack) and the Code 3 pulley (adds slack). To run the 181 you have to run a smaller water pump pulley (adds slack).
So I'm guessing that equates to some where around stock as far as belt length goes. I don't have a stock setup to try it on at the moment so I guess you get to tell us if it works stock Krazy.
I'm guessing yes.
