Old Jul 10, 2009 | 06:56 PM
goodgenes79's Avatar
goodgenes79
Default Re: IC tank separation question
I checked the pump to make sure the connector hadn't worked loose, and it hadn't. The fuse is good so not sure what would have caused it to crap out without warning. Anyway, I just wanted to see if maybe I hadn't pulled something loose while removing the coolant reservoir. I know I broke the little prongs in the coolant level connector, but I just put them back together and shut the connector, hoping they would make contact and still work, slightly.
I was just curious what the other pump was above the IC pump. Is it an assisting water pump? what are the two selenoids that it pipes to above the wheel well? I hate not having answers, and not have parts to replace right now.
