modded thermostat
Jul 16, 2009 | 02:34 PM
26
permalink
waldig
Feb 2008
4,508
34
VA
Re: modded thermostat
Drilling is worthless, If you want to get more flow without making or buying a 180 stat, just pull it out in the summer and replace in the fall. THe codes are easy to reset if you get one and if you are playing with stats you must have a code reader as a tool for checking and resetting. The tools are cheap.
Stat contols the water and the fan or forward motion cool the radiator.
Looks like I should get to finishing the fan mod that I started over a year ago. A lil box that generates a signal to speed the fans is what I have in mind for the forums "heat producers".
I did something like this for drag racing and it worked on the line to cool the motor, AND I even wrote up the story about it and offered the parts (FREE) to do it. THat was simple resistor to up speed the fans when the car is staging AND NOT RUNNING ON THE STRIP cause it would pull timing in that event.
ENJOY W
DY trying to stay Cool...........
waldig
View Public Profile
Send a private message to waldig
Find all posts by waldig
