Oil Leak...how tight should the filter be?
Jul 20, 2009 | 03:48 PM
16
permalink
waldig
Feb 2008
4,508
34
VA
Re: Oil Leak...how tight should the filter be?
Standard automotive practice is to tighten threaded components by tighten them until they just strip out the threads and then em back off 1/2 turn. That will make you feel better but it is still stripped.
Better approach is to wipe off the threads and pre oil them and o rings before tightning. Its plastic dont go as tight as you can; cause that often means that it will break.
My Dakota has a similar cap and I loosely tighten it with a few fingers. To remove it I have to use really big channel locks to get it to even budge. I pre oil and it's still is tight.
With the C, I snug it up and that has always been good, I change every couple of months; recycle the oil to the mowers.
No leaks and I autocross frequently, high revs for a minute.
Woody
waldig
View Public Profile
Send a private message to waldig
Find all posts by waldig
