Ok, more questions.
#1:
In BrianBrave's IC separation thread:
https://www.crossfireforum.org/forum...lant-tank.html
What is the benefit of doing the "BrianBrave" setup over the modified setup?
attached is my proposal, it would merely be an overflow tank just in case, b/c I am running the stock HE.
I am trying to keep as stock as possible, and I do a lot of sitting in traffic (no air flow to engine radiator, and I like using my AC).
#2:
I don't plan on ever using ice, and I imagine that the hose routing would require a lot more work... would putting the reservoir in between the HE and the IC pump benefit cooling at all? NOTE: not going to add ice.
#3:
Excluding the cap, would the tank need 2 or 3 inlets/outlets - 1-inlet,1-outlet,1-overflow outlet (like on the stock tank)? Does it need the overflow outlet just in case or for air/fluid expansion? I only plannned on keeping the tank half full.
Thanks in advance.
Regards,
Steve
