Originally Posted by Black SRT
Well I got the problem fixed. I unbolted the inner bolt for the control arm, the one that connects to the frame. I'm guessing I tightened it too much before I got it on the ground and preloaded the spring or I over torqued the bolt finishing up. I loosened the bolt with it on a jack then put it back on the ground and torqued it to 40 pounds, no more clunking.
Black SRT,
Just curious if you've notice any rattling? Most noticeable over rougher roads.
I too had the clunk and figured I over tightened the bolt before dropping the car back on the ground… I did the same thing as you and it hasn’t come back since.
