Re: Manual Transmissions-Good or Not?
I never had it pop out of gear but does anyone else run into strong resistance when putting it into 1st? Sometimes it goes right in, smooth as can be. Other times its like trying to push it in from neutral without using the clutch. I usually just have to push harder and kind of force it into gear, then I let up on the clutch and go. It's not like I have to RAM it into 1st with all my strength, but there is definately a noticable resistance I must push through to make it. Or if I let up on the clutch and push it back down, it will go in smoothly. 2nd through 6th never had the same issue.
Anyone else experience this exact thing?
