Old Aug 9, 2009 | 02:28 PM
Mike-in-Orange's Avatar
Mike-in-Orange
Default Re: Polishing Speed?
Originally Posted by xfirepop
I just received the Lake Country pad set with the backing plate and centering post. But for the all gyrations I've done I don't see how the centering post works. It doesn't attach to anything. I feel real dumb, but how does that ^*)^%&*)( thing work? I'm anxious to go to work on my coupe but can't get the pads centered.
Any help would be greatly appreciated!
xfirepop
The centering post from Lake Country is designed to be used with their pads that have a center hole when attaching them to the rotary backing plate, which also has a centering hole. You stick the post in the hole (without trying to conjure up all sorts of perverted imagery - I know you guys on this forum pretty well!!) on the backing plate, drop the pad over the post, and remove the post.
On a D/A this exact centering of the pad is not anywhere near as critical as it is on a rotary due to the oscillating action of the D/A. Just eyeball it real good and you'll be fine.
