Re: Pulley Saver Kit
[rcompart]Why would you want to even do the DIY belt wrap? You're not getting away from the small diameter pulleys and it's spinning them at ridiculous speeds.
I used the DIY belt wrap because I had slippage with the Code3, now I don't and have better performance. The only pulley that is spinning faster is the S/C pulley so not concerned with that. If and when I add a crank pulley then I can change my set-up.
Although this would be a bit safer on long-term for all setups.
