Old Aug 18, 2009 | 11:38 AM
  #80 (permalink)
Bubba89's Avatar
Bubba89
Default Re: Pulley Saver Kit
I'm doing the same thing Tighed is to remove my belt and it works like a charm. I found that positioning the wrench so your pushing across to release the belt helps it from not loosening up, if you push down it tends to loosen every time. I used it to install the Tighed belt wrap kit coupled with my smaller supercharger pulley and 178 set up and it worked quite well so it should be able to work fine with the 185 install also.
Brandon
