Re: EC tune results over existing other tune
Originally Posted by Steve Hellums
Reaching max touque in 300 RPM's is probably how I can pull off the 1.7-60' 12.510 @ 111.62 with a lot lower dyno #'s than others running around the same times. But I'm not knocking anybody cars or tunes. But I would like to get it leaned out a little and increase the temp setting to get the timing not to start retarding at such a low temp, I'm sure it is set very consertive.
am i correct? you have a renntech tune and a 178 pulley and still only get 297 ft/lbs torque and under 300 hp? granted the lines look great but to have that done andhave such low numbersseems strange to me. my engine pulls 317 ft/lbs torque and 321 hp in stock form. granted my lines look a little ragged but my ecu doesnt care for dynos much. the reason i ask is mine was also done on a mustang dyno.
