Old Aug 29, 2009 | 04:45 AM
dedwards0323
Default Re: What is the correct PSI?
Originally Posted by danimal
Save your money. Buy a good quality air guage and check the pressure once a week if you want to be really **** about it.....less often after you feel more comfortable with it.
Check here for a better quality gauge:
http://valvelock.net/?gclid=CMeS-o_7xpwCFQ7xDAodjWayJw
The advice above is sound. I think I'm pretty **** about tire pressures and I check every 45 days on all my vehicles. Another good thing to remember is that the tire pressures we're typically referring to are under cold conditions. That's really the only way to know for sure. If you check your tires after driving awhile, you probably ought to assume 3-4 psig higher readings since the elevated tire temp raises the internal air pressure.
