What is the correct PSI?
Old Aug 28, 2009 | 09:23 AM
blackcrossfire07's Avatar
Default What is the correct PSI?
What is the correct PSI on a stock crossfire base coupe? I know it is written on the door jam but my car is stored somewhere and I will not see it for a while. I wanted to order a part and need the correct PSI. Thanks guys!
Old Aug 28, 2009 | 09:27 AM
Default Re: What is the correct PSI?
It's 32 for the fronts & 33 for the rears. I usually keep 35 in all 4.
Old Aug 28, 2009 | 12:38 PM
Is it ok to keep 35 PSI in all of them?
Old Aug 28, 2009 | 12:54 PM
danimal's Avatar
36 psi is recommended all around for high speed/spirited driving. Otherwise 32 F/33 R.
Old Aug 28, 2009 | 01:08 PM
I keep mine at 35 all around.
Old Aug 28, 2009 | 02:00 PM
I don't have a Tire pressure monitor on my car because it is a base coupe. Had my car 4 years and visually inspect the tires every morning and afternoon after work. But it is very difficult to tell on our tires! I am getting those valve caps that use colors to tell if the tires are low or not. Anyone use them? Do they work well?
Old Aug 28, 2009 | 02:08 PM
danimal's Avatar
Save your money. Buy a good quality air guage and check the pressure once a week if you want to be really **** about it.....less often after you feel more comfortable with it.
Check here for a better quality gauge:
http://valvelock.net/?gclid=CMeS-o_7xpwCFQ7xDAodjWayJw
Old Aug 28, 2009 | 02:17 PM
Stogey's Avatar
I'm with danimal, buy a good quality tire guage. Like most on this thread, I run 35psi all the way around.
Old Aug 28, 2009 | 02:25 PM
danimal's Avatar
.... I am getting those valve caps that use colors to tell if the tires are low or not. Anyone use them? Do they work well?
You had better check this thread out first:
https://www.crossfireforum.org/forum...6303-tpms.html
Old Aug 28, 2009 | 09:33 PM
CresFresh's Avatar
Yeesh, thats a good example of what happens when two dissimilar metals sit agianst each other for to long. Another great example is the old land rover series trucks!
Old Aug 29, 2009 | 04:42 AM
Like others in this thread, "works for me".
Old Aug 29, 2009 | 04:45 AM
The advice above is sound. I think I'm pretty **** about tire pressures and I check every 45 days on all my vehicles. Another good thing to remember is that the tire pressures we're typically referring to are under cold conditions. That's really the only way to know for sure. If you check your tires after driving awhile, you probably ought to assume 3-4 psig higher readings since the elevated tire temp raises the internal air pressure.
syfi
Mar 28, 2026 04:14 PM
Reliableron
Oct 17, 2015 10:19 PM
nataliefs
Oct 5, 2015 01:03 PM
skeet370
29
Sep 18, 2015 05:53 AM
jaesa
Sep 7, 2015 01:50 PM
