Originally Posted by Rasim
Thank you very much how can i do throttle reset? what about dust cover? and harmonic damping ? and how to check the boost?
Here's a link for
Throttle Reset again it's so you can drive agressive and the ECU learns that pattern for quicker response.
What are you going to use to monitor your boost? I would recommend a datalogger with a laptop to see a graph of your runs. Once you get a baseline then you won't need to hook it back up unless you do additional mods or car starts to run different. With the zietronix you can get the o2 sensor, and boost sensors as optional equipment but recommended. Heres the Zietronix I have.
Datalogger from Needswings with o2 sensor included and here is the
Boost Sensor.
To your dampner question. The ASP 178 is the only crank pulley available that is a harmonic dampner. It's because a factory crank pulley is used to make the ASP 178. There is a old discussion that a crank pulley needs this for our motors. One half one way the other half the other way.
