Re: Needswings or code3 pulley saver kit?
if you are running a c3 pulley you need a c3 wrap or tigheds diy wrap. i have been in contact with rob in detail about his pulley saver for my c3 setup and as it stands it doesnt appear to work. he is researching the feasibilty of a pulley saver for the c3.
the main diff is the c3 is strictly a wrap to keep the s/c pulley from slipping.
robs setup is larger pulleys to offset the crank pulley spinning everything faster and the wrap is a byproduct of the pulley and belt alignment if you look at the fotos of the pulley saver the pulley next to the s/c pulley is relocted underneath the s/c pulley and is larger.
there wouldnt be much benefit to slowing down the acc. pulleys with the c3 because the crank turns at oem speeds
the best thing for now may be to wait to see what needswings comes up with for us c3 guys
