Accessory Plug
Sep 8, 2009 | 02:54 PM
permalink
tighed1
Aug 2008
5,743
99
Sierra Vista, Arizona
Re: Accessory Plug
Quote:
RickZ
...on a side note I still can't figure out why the horn is only
powered with the ignition on
Power to the horn relay is present all of the time. However there is no power to the coil on the relay so the relay can't operate until the the ignition is on. One side of the relay coil is connected to ground when you press the horn button on the steering wheel. The other side doesn't see 12v till the ignition is on. Once current is flowing the relay connects the always hot 12v contact to the horns. Beep - beep!
One member had someone back into him and all he could do was watch because his horn wouldn't work cuz the key was not on!
There is a fix for this now. Check it out if you want 24/7 horn access!
How to Always Ready Horns
tighed1
View Public Profile
Send a private message to tighed1
Find all posts by tighed1
