Re: Changing Camshafts
you basically relocate pin closer to fulcrum, then make a larger diameter roller to take up the added clearance created by moving the pin in to the fulrum.
another way is to grind the cam base circle diameter, not the lobe, then install a larger roller bearing tip in the stock rocker arm, this might be as much work.
