Thread: SLK Rotors
Old Sep 24, 2009 | 09:37 AM
BoilerUpXFire
Default SLK Rotors
I have been searching and searching...
I can not find anywhere that someone actually talks about USING SLK320 rotors on the XF. I have found several places where someone will say "they are the same, sure they will work" and then I read about HDDPs efforts to use a brembo system for the SLK320 and it would not fit. Is this because of the other components or the rotors?
Basically I need to verify (before I order everything) that the front and rear rotors and pads from a SLK320 will work on the XF with zero issues.
Thank you.
