Thread: Flash Tunes
Old Sep 30, 2009 | 07:43 PM
cruzinquick's Avatar
cruzinquick
Default Re: Flash Tunes
Originally Posted by distantpulse
Ok so basically your 93 InMotion Tune is my LET stage II tune we'll say. From our runs, the only difference is the DA. Yours being 2100' and mine, if I were to guess, probably around 500' or better. Technically I should put up better numbers, but due to mine leaning out at the top end, I am not. This is probably why you are trapping a few mph's better at the stripe. What is your 1/8 mph? Mine is right around 88-89mph. So.......would you say that LET's Stage II tune is comparable to InMotions 93 tune? I believe once I get this leaning issue fixed, I will be consistantly in the 11's in good air. I have some other things still in the works, but for now I want to see if the tune can get me there.
Yea that sounds about right. I have to hunt down my 11.97 slip, but my 12.02 was 90.11 mph and my 11.89 was 92 mph at the 1/8th. I've done the time splits on here before and my 660' on to the 1320' is comparable to a high 10's bracket car. Your about tenth slower than mine in comparable DA, and probably is due to leaning. This winter I hope to run sub 1000' at sacramento, we can compare lower DA then.
