Originally Posted by cruzinquick
Myself and possibly distant would be curious to your afr's on the top. If yours are good under 500' DA then distant could use the tune you are running. Still your mph isn't high either. Definitely should be on your must do before you hit the track again.
I would bet a good bit of money Mikey is lean on the top in good air. At 11.96, his mph should be higher. By no means am I talking smack on LET, but every tune I had so far went crazy lean in 3rd in good air. Not sure why, but we are working on it!
