Originally Posted by distantpulse
It was 177 get it right! :P lol
No, but seriously, every tune I have had has done the same thing. The IAT problem is a new issue that I wasn't aware of before. I am going to check the IC pump just to make sure it's working. Then im going to try and get all the air out of the system and go from there. Might have to upgrade to the supercooler.
I keep heearing supercooler this and supercooler that, but honestly I would worry about getting your temps WAAAAYYYY down first. Then once down, if you want to get them down a couple degrees more is fine...
immediately switching to the supercooler now when you know you have a IAT problem is like putting a poster over a hole in the wall...sure it may be good, but you still have a hole in the wall.
