Originally Posted by 911split
HDDP,
Whatever happened to testing the 2" bump stops with your Eibachs to see if it would eliminate the rubbing issues up front? You said you were going to test them Jan. 22-23. Did it work? I've had my Eibachs here for almost 2 weeks (still in the box) waiting for your track results before i do the installation. I'd like to do the install once and get everything dialed in right off the bat.
Also... i showed my father my XF Sunday nite. Monday afternoon he called me and told me he just bought a XF! We've both been into cars for a long time, and for the first time we're both into the same kind of car. It's gonna be a lot of fun working on our XF's together. I'm looking forward to it!
Sorry, I've been out of the loop for a week because of work. In answer to your question. Yes, the bump stops worked fine. Make sure you get the right diameter for the koni shocks and 2" in length. I have been a fan of "Energy Suspension" products for years. If you are keeping your OEM shocks then you will not need to replace the bump stops.
