Originally Posted by H82BL8
Some gel superglue I had around the house. Didn't use much, center cap was still a tight fit.
Exactly what I did, but make sure that you let it sit out in the sun on a warm day for at least a half hour or else you will get a white haze on the inside of the lens from the chemical reaction of the Super glue.
Another thing is that if you get the 'O' ring wet, a little Vaseline, or just some spit (my personal choice) it slides together just like it is supposed to, no need to poke at it.
Did the one side that was broken, including taking the front wheel off, and putting it back on, it only took an hour (not including drying time).
I had to fight with the access door a bit, so I took the wheel off, while I was at it I got a pic, only one missing from your set.
