Old Oct 16, 2009 | 08:50 PM
Rob M's Avatar
Rob M
Default Re: Oil filter - paper vs. fiberglass / fleece
120 psi? Can this be verified by anyone here?
At operating temperature and over 3000 rpm, normal oil pressure can range from 45-105 psi. At curb idle oil and operating temperature oil pressure should be a minimum of 5 psi. So at startup 120 psi is possible. But the pressure doesn't harm the filter because the filter is porous so it doesn't provide enough resistance to the flow to cause it to deform or "disintegrate".
