Old Oct 28, 2009 | 01:53 PM
sowardcustoms's Avatar
sowardcustoms
Default Re: Body Controller - power window problem
I dont know if this is your problem but here is a tech tip on the BCM... If you are replacing the Body Controller Module (05099700AA, 05136131AA, 05189811AA) due to backlight issues or window does not go down when turning handle to open convertible top, check the status of the header switch with the top closed. The switch should be in closed position. If the switch is in open position, then replace the header latch plate switch (05166831AA
