Old Nov 15, 2009 | 08:46 PM
pizzaguy
Default Re: Experienced Xf Advice
Originally Posted by FUBU
Hi everyone,
I am going to check out a XF limited on saturday.
I need some expertise from you guys, I have never driven, sat or touch an XF. I need some help giving me hints on what too look out for. This is what I have got so far:
- seat heating mechanism faults
- valve coat leaks (or something similiar...pardon my bad english ;D) How can I check this?
Help me out PLS! I wanna join the gang!
Valve cover leaks have been reported. I am assuming that you will see oil on the sides of the engine in the area of the spark plugs.
The relay control module has been a problem for some, but it's usually a repairable item - a little touch-up soldering is all that's needed.
My 2005 has over 18,000 miles on it and my only complaint so far is that the convertible top release latch button is stuck in. No big deal!
I'd look for the usual: oil leaks, condition of tires, listen to noisy valves or other engine parts (that would indicate a possible serious problem like low oil pressure or engine damage), maybe look for rust around the bottom of the doors (there is a thread here that talks about how to pull the seal off so you can see).
Be encouraged:
SEVERAL forum members have over 100,000 miles on their cars and they appear to think nothing of jumping in the car and heading out across the USA on trips!
