Old Nov 16, 2009 | 03:42 AM
Russelio's Avatar
Russelio
Default coolant expansion tank issue
Good morning,
I have searched the forum with no success on my issue. I have an '06 coupe 20k miles and whilst detailing the car I noticed what seems to be a sensor wire come adrift from the underside of the black plastic coolant expansion tank area.
The sensor (I presume that is a sensor) wire is a thin double wire with an inch long soldered tip coming from a black plastic connector. I noticed that the underneath of the coolant tank has a collared recepticle that the the loose wire/connector sort of fits into, albeit not a very snug fit, so I pushed it in. I idled the engine to check that the fan cuts in and it did.
Any thoughts? Should I worry?
Your advice would be appreciated
Enjoy your day and thanks for this great forum
Russ
