coolant expansion tank issue
Old Nov 16, 2009 | 03:42 AM
Russelio's Avatar
Default coolant expansion tank issue
Good morning,
I have searched the forum with no success on my issue. I have an '06 coupe 20k miles and whilst detailing the car I noticed what seems to be a sensor wire come adrift from the underside of the black plastic coolant expansion tank area.
The sensor (I presume that is a sensor) wire is a thin double wire with an inch long soldered tip coming from a black plastic connector. I noticed that the underneath of the coolant tank has a collared recepticle that the the loose wire/connector sort of fits into, albeit not a very snug fit, so I pushed it in. I idled the engine to check that the fan cuts in and it did.
Any thoughts? Should I worry?
Your advice would be appreciated
Enjoy your day and thanks for this great forum
Russ
Old Nov 16, 2009 | 02:40 PM
maxcichon's Avatar
Default Re: coolant expansion tank issue
Someone MAY have removed the tank to service the pass. side headlight and failed to replace the coolant level sensor connector.
Old Nov 18, 2009 | 02:47 AM
Russelio's Avatar
thanks for your advice.
I found the service manual on the forum and looked for the diagram for this area and it showed that a grommet is missing that holds the sensor in place
regards
minimayhem
16
Aug 23, 2016 07:47 AM
janaiy
53
Nov 2, 2015 09:23 PM
Reliableron
Oct 17, 2015 10:19 PM
bobbie
Sep 12, 2015 12:49 PM
MickeyNasty
Sep 6, 2015 08:29 PM
