Old Nov 19, 2009 | 05:09 PM
mrphotoman's Avatar
mrphotoman
Default Re: Eibachs on SRT: upgrade or downgrade
Originally Posted by velociabstract
Well the Eibachs are on, as well as the adjustable camber arms in the rear. The drop on the front with the dot 5 pads on the front is 1/2 inch. On the rear with the dot 1 I got 1 1/2 inches of drop. The car sits level and no rubbing. (I have 235/40/18 on the front) As far as the ride .... I really can't feel any difference. I couldn't get more negative camber on the front even with the drop but the rear has plenty. This weekend I have a track event so afterwards I should have more information. I'll be watching the stopwatch to see how much difference the lower center of gravity, new springs and rear negative camber made. I'll upload a pic or 2 later.
Les
if you have positive results with the handling i may go this route. as it is right now, i am afraid to mess with the suspension since the spring ratings on the eibachs show they are lighter. I hope things work out well and good luck at the track!
what tires are you running btw?
