Old Nov 29, 2009 | 06:56 PM
ppro's Avatar
ppro
Default Re: Installing SONY GPS unit ... want to wire it in directly
Check the instructions for the GPS hardwire kit to be sure - usually the red wire is the power (red goes to a switched 12v lead) and black is ground.
The blue thing in the picture is a crimp connector and you just insert the red wire into the opening and using a crimp tool, pinch the blue part a couple times to hold the wire in place.
You can add multiple devices this way, and a GPS doesn't take a lot of power. It would be cleaner to run the wire from the piggy-back fuse device shown to a split connection that allows you to wire in each device.
I used a fuse panel to split the power into six different items. Then I connected the various devices to the fuse panel.
