Installing SONY GPS unit ... want to wire it in directly
Old Jul 6, 2011 | 01:41 PM
joejones's Avatar
Default Re: Installing SONY GPS unit ... want to wire it in directly
Originally Posted by ppro
Or you can run it to the switched power outlet in the fuse box (fuse 5 in the underhood accessory fuse box), which will cut power when you shut off the car.
I used a Littlefuse FHA200BP ATO Fuse Add-A-Circuit Kit to piggy-back a fuse in that slot.
I added a fuse panel just for my GPS, stereo components, cell phone, and radar detector.
Here's the auxiliary fuse panel diagram.
Fuse Box Write Up
OK, ATO fuse, ATC fuse, what is the difference (if any) and does it matter? And, I notice everyone goes to the engine area fuse box. Can you use the fuse box inside on the left side of the instrument panel by the driver's door?
Old Jul 16, 2011 | 07:22 AM
TomStratRT's Avatar
If you look in the Crossfire Service Manual, on page 1325 (section 8W-10-12), you can see on the diagram that fuse 12 is wired to power up with the ignition switched on, but it's not in use. I used this to hardwire my GPS. Works perfectly.
Old Jul 16, 2011 | 09:41 AM
joejones's Avatar
Why do all the hardwire installs go to the fuse box in the engine. Is there anything wrong with using the one on the L side of the dash?
gp1200x
Dec 6, 2015 12:59 PM
pioneer4x4
Jul 27, 2015 02:04 PM
Bayukbros
Jul 17, 2015 04:22 PM
shawnwatson9493
Jul 9, 2015 11:47 PM
bdh
Jul 9, 2015 09:40 AM
