Originally Posted by dejohnny
I'm having the same issue with turning the keys from time to time. Try injecting some silicone in the keyhole.
If you are having a sticky key problem silicone will not fix it - the problem isn't in the keyhole - please search "sticky ignition key fix" - mine has been fixed for 3 months by removing the pin and spring - no parts required just time (lots if you are like me!) It won't get better until you fix it.
