Old Nov 30, 2009 | 09:19 PM
ppro's Avatar
ppro
Default Re: Installing SONY GPS unit ... want to wire it in directly
That's the same as putting both into the same crimp. One fuse replaces the one you removed to install the add-a-fuse; the other fuse (the one you have going to the radar detector) also goes to the new wire.
sonoronos did exactly the same thing I did - add a fuse box under the floor - I actually added two - one switched and one unswitched. The diagram is up on this thread.
What you are drawing will work as long as you don't have a problem with one of the devices that blows the fuse.
Originally Posted by XLR8BYU
Good thinking. I would definitely not want to start messing up fuses by overloading them. So, rather than crimping both wires to the add-a-circuit, how about this:
