Panel warning lites & spoiler up
Panel fail lites on & Spoiler stuck up - Yesterday , 05:33 PM
Lites on ABS, Bas,ESP, Brake, Engine, Brake wear Lites.
After repairing 2 wires (Criter Damage) one in abs system and one in brake wear circuit and extensive check out. Went for a test ride and all normal. When pulling in the drive way The above lites came on and the spoiler drove up was able to drive down manually. Shut down and restarted all lite back on and spoiler drove up and stayed up.
Wrung out every ciruit between the BCM and the CAB including grounds and Power and x links.. All ok Battery voltage 13.5 v.
Tried a used BCM that was worse with the Wipers and interior lites not working. Tried a new BCM because of the spoiler with same problem.
It cost $180 for the first hour and computer test at the dealer. Which I am sure will not pin down this problem
Tried a good battery still no help. Found out if you happen to have locked the doors and start removing the battery the alarm goes on and could not control , finally stopped by itself and Car battery removed. Came back on with the newer battery and stopped by itself. The key switch was no help
Have noted with the engine light on and shifting it to gear very hard. Rpm is up also.
Still Looking for any suggestions. I have scoured all the manual descriptions and wiring prints for anything common. Going to start over.
Bibbs / jer
