Re: My Butt is Hot! (Seat Heater)
The Heated Seat System will operate only when the Ignition Switch is in the ACC or ON/RUN position. The Heated Seat Module receives switched power through Fuse 1 and non-switched power through Fuse 24 in the Underhood Accessory Fuse Block. Individual illuminated Heated Seat Switches control each seat and are designed as toggle switches that return automatically to their original position after being pressed. The switches and control module for the heated seats are consolidated into a block with other switches to form a Switch Group. Switch illumination is provided through instrumentation lighting. The Heated Seat Control Module controls the differing electrical power consumption requirements of the heated seats in each heating stage and heating time.
