Old Jan 8, 2010 | 12:35 AM
Bulldogger's Avatar
Bulldogger
Default Re: Eurocharged SRT-6 Fuel pump upgrade Kit Pre order
Originally Posted by EUROCHARGED
Yes you will need some fueling tweaks to get this dialed in.
Cut and splice 2 wires and clamp on the supplied wires for power and ground. The posts are a bit larger then the stock fuel pump. Everthing else is plug and play.
Why aren't you going with the SL55 pump which is a direct replacement and takes 15 minutes to install??
