Originally Posted by Teck-9
What? the block, the cylinder heads, the pistoins, the cam shaft, the crank shaft, what else is different??? I've got a damaged AMG engine, what else do I need from it. I will just make an AMG engine that will take boost.
Did you buy the engine already? If so, take some pictures.. and just a tip.. Use the best camera you have available to you, and use the macro switch (usually 2 settings, either mountains for far away and flowers for close up)
. What's damaged on this thing?
