Old Jan 26, 2010 | 09:46 PM
onehundred80
Default Re: Clicks, but won't turn over.
Originally Posted by Veloce
Simple things first. Have the battery tested (Autozone will do it for free). They put it under a simulated load to determine if it will hold a charge. Could be as simple as leaving something on (interior light, door light, etc, etc).
Logic would suggest that if a battery just produces clicks when attempting to start a car a few times and then suddenly starts the car then the battery is not at fault.
Batteries do not suddenly jump to life, a short inside the battery would not suddenly fix itself.
A bad ground or a bad connection could produce intermittent problems, but my money is on the starter or solenoid.
