Old Jan 27, 2010 | 02:40 PM
tighed1's Avatar
tighed1
Default Re: Clicks, but won't turn over.
Originally Posted by tighed1
Well now that you can start the car, drive it to Autozone (or someplace) and have the battery load tested.
If nothing else you will know the status of the battery.
Originally Posted by Veloce
Thought so...
Now you need to do a couple of things:
1) Drive your car down to Autozone and get a free load test on that battery to make sure it can hold a charge; If it won't getting a new battery is a good idea.
2) If your battery is good you should start to try and figure out why it was down. Parasitic drain, etc.
Good luck
When you are through playing with the starter take that battery in to Autozone, PepBoys or whatever and have them test it (free). It may have the voltage but not enough amps to crank the car.
Simple things first. Have the battery tested (Autozone will do it for free). They put it under a simulated load to determine if it will hold a charge. Could be as simple as leaving something on (interior light, door light, etc, etc).
Are you mocking me???
