Old Jan 27, 2010 | 07:29 PM
onehundred80
Default Re: Clicks, but won't turn over.
Originally Posted by Rennie Mihalovic
Thanks one and all for the prompt suggestions.
I pulled the battery out, and noticed some corrosion on the negative terminal. I charged her up for an hour and that got her back to 12.57 volts; cleaned up the corrosion, sanded the bottom and inside of the negative terminal connector, reinstalled the battery and started her up. She turned over without any hesitation. It was a beautiful sound, even if it was coming from a black crossfire.
Sorry, I doubted the starter. The battery, I noticed, is almost four years old, so I'll keep an eye on that.
Thanks again. A guy my age should've done all that before I bothered you guys. What a short sweet solution.
rennie
My battery was almost six years old when I replaced it and I never had any trouble with it. Get some of those anti corrosive washers or grease up the terminals.
My #2 post covered terminal corrosion, so stick with the guys with black Crossfires and you'll do OK.
