Originally Posted by JHM2K
BCM = Body Control module...
You said you turned off traction control and planned on doing some donuts/drifting... but the BCM (if I remember correctly) stays active even when TCS is disengaged. So the electronic nannies will still 'arrest' your fun... Killing the BCM allows lots of drifting, but also kills ABS, so play carefully...
I thought that was what you were refering to (the BCM cutting in) but so far, I haven't noticed it spoiling any of my fun. But then I don't do donuts anymore either. (Don't plan on starting either)
As far as the ABS is concerned, I don't miss it. But I know if I ever have an accident that could be remotely linked to the ABS being shut off, I'm sure you guys will never let me live it down.
I'm just not a big fan of anti-lock brakes thanks to some "close calls" I've had in 4 different GM cars I've owned. A Vette, a Z-28, and two Chevy Vans.
