Code3 + 178 or 181 or 185 pulley
Feb 4, 2010 | 08:59 PM
permalink
tighed1
Aug 2008
5,741
98
Sierra Vista, Arizona
Re: Code3 + 178 or 181 or 185 pulley
Quote:
PA/XFIRE
I think your running rich because your at 4000' Which code 3 are you running
with the 181 crank ? How much boost ? How much boost are you running on the 192 crank ? Do you think your exceding the rpm rating of the supercharger ? THANKS FOR THE INFO ILLCYA
I also believe the 4600 ft elevation has something to do with it.
Running the 2nd Gen Code 3.
Max boost is 19 lbs (or so) varies +/- with weather.
192 pulley I think (car is in the shop) is 'round 18 or so.
Do you think your exceeding the rpm rating of the supercharger ?
When my S/C went before (seized) I was driving very hard, constantly accelerating and exceeding 100+ mph speeds for a good 30 miles or so. When I turned off the highway a got about 3 or 4 miles then the S/C locked up. I believe that it was due to the fact that I ran at higher RPMs for that extended time that caused the failure.
But that's just my 2 cents!
Comments anyone?
Whyjay
tighed1
View Public Profile
Send a private message to tighed1
Find all posts by tighed1
