Code3 + 178 or 181 or 185 pulley
Feb 4, 2010 | 09:29 PM
permalink
PA/XFIRE
Sep 2007
436
Re: Code3 + 178 or 181 or 185 pulley
2nd generation that would be 65 mm.Hmmmm when i was running a stacked 178 crank
and the c3 68 mm (c3 midsize ) boost was over 20 + psi but a/f leaned out bad. Prior to installing the 178 mm crank, i ran the midsize c3 by itself and that got 17.5 psi by itself.I had the original c3 65 mm and with that i would run 18 + psi. I thought the midsiize c3
should have been around 70 mm, i believe thats what slk32 stacked setup is. Interesting
stuff
ILLCYA
PA/XFIRE
View Public Profile
Send a private message to PA/XFIRE
Find all posts by PA/XFIRE
