Old Feb 15, 2010 | 04:05 PM
///SilverSaphRT6's Avatar
///SilverSaphRT6
Default Re: Intake Valve Covers Leaking
Originally Posted by MikeR
If you're talking about your air intake boxes, they seal against the filter. If the filter is installed right, there should be no issue.
If you're talking about the manifold plenums, make sure that the bolts are torqued down to spec.... you should be seeing some issues with the engine running if you have a leak here though. Worst case, get a set of NW gaskets and intall them. Easy DIY and cheap....
How did they determine there was a leak??
Yeah these ones.....I think the gaskets is what he was meaning. I have now idea how he determined it...I have no drips in Garage since tranny fix. Guy couldnt fix the service light indicator sooooo.
