Intake Valve Covers Leaking
Old Feb 15, 2010 | 02:36 PM
///SilverSaphRT6's Avatar
Default Intake Valve Covers Leaking
I just got back from getting my 6 serviced @ Carmax and they said that both my rear intake covers are starting to leak. Have any of you guys replaced your gaskets and if so was it a hard DIY? Thanks in advance.
Old Feb 15, 2010 | 02:43 PM
MikeR's Avatar
Default Re: Intake Valve Covers Leaking
If you're talking about your air intake boxes, they seal against the filter. If the filter is installed right, there should be no issue.
If you're talking about the manifold plenums, make sure that the bolts are torqued down to spec.... you should be seeing some issues with the engine running if you have a leak here though. Worst case, get a set of NW gaskets and intall them. Easy DIY and cheap....
How did they determine there was a leak??
Old Feb 15, 2010 | 04:05 PM
Yeah these ones.....I think the gaskets is what he was meaning. I have now idea how he determined it...I have no drips in Garage since tranny fix. Guy couldnt fix the service light indicator sooooo.
Old Feb 15, 2010 | 04:28 PM
MikeR's Avatar
The factory plenum gaskets are actually metal, they would be hard to go bad if you have never taken them out and damaged them. Check the torque on the bolts and make sure that they are tight. Are you having a problem with power or whistling sounds?
Maybe he is just trying to jack you up for some extra business.......
Old Feb 16, 2010 | 11:56 AM
No problems at at with power or whistlin sounds other than the SC. Ok I will check on the bolts....thanks Sir
Old Feb 16, 2010 | 12:07 PM
rcompart's Avatar
Is it leaking oil? I'm guessing this has nothing to do with intake plenums and everything to do with the valve covers. It's a simple fix and will take you about an hour depending on how handy you are with a wrench.
Good luck with the fix
Old Feb 16, 2010 | 07:57 PM
ckovach's Avatar
I'll bet they were referring to the crankcase ventilation plenum covers on top the valve covers...those don't have gaskets (they're assembled onto valve covers with silicone bead) and they leak notoriously.
RojoGTO
Feb 6, 2016 11:14 AM
Snake Eyes
Sep 28, 2015 08:55 PM
Codyktt
Aug 25, 2015 02:48 PM
rmcdaniel12
Aug 7, 2015 01:37 PM
Selbyl
Jul 30, 2015 09:09 AM
