Originally Posted by t_ediz
Rudy
I saw the epictures posted by dkerns.
Dkerns thanks alot for taking the time doing this. I am really suprised that this thing has Ipod connection, as well as 2USB and AUX outputs. This means I should be able to put a USB p[owered HD in the glove box for permament music library. I didnt understand exacty what you did with the set up in the center console. But seems like you are enjoying your new ipod music collection in your XFire.
Rudy
Can you let me your info so I can order one for myself?
Thanks
In the pictures of the hardware I took prior to install I had a silver 4 port hub connected that I ended up not using. I thought the same thing Rudy had mentioned about pulling to much current. So I ended up just connecting a short usb cable with a gender changer on it so I could plug in a USB jump drive.
As far as running the cable, I do not know how to explain this very well but you can flex the center console panel beside the glove box at the top. Then poke the cables into the center consol cavity beside the radio. I just tied them up and put them in the web holder on the right side of the center console.
I am glad the pictures had some value.
